*tablepopulate
Populates a table with data from a delimited file.
*tablepopulate name filename delimiter
HyperMesh Tcl Modify Command
Populates an existing table with data from a delimited file. The data in the file must match the format of the columns defined in the table. Additional rows are appended to the table and existing data remains.
name
The name of the table to populate. The table will be overwritten with the data from the file.
filename
The full path and filename of the file to use to populate the table.
delimiter
The character or string to use as the delimiter. The value must be enclosed in quotes. If not specified, the default is a comma (CSV).
Examples
To populate table1 with C:/table1.csv, which is a comma delimited file:
*tablepopulate table1 C:/table1.csv ","
or
To populate table1 with C:/table1.txt, which is a space delimited file:
*tablepopulate table1 C:/table1.txt " "
   # Handle error
Version History
11.0
