*unsetparametermark
Unparameterizes a data name or attribute on a mark of entities.
*unsetparametermark entity_type mark_id data_name_or_attribute row column
HyperMesh Tcl Modify Command
entity_type
The type of entity to unparameterize.
mark_id
The ID of the mark containing the entities to unparameterize. Valid values are 1 and 2.
The data name or attribute name/ID to unparameterize.
row
The row index of the attribute in a 1D or 2D array. Must be set to 0 otherwise.
column
The column index of the attribute in a 2D array attribute. Must be set to 0 otherwise.
To unparameterize attribute LSD_DA1 on entity sets 5, 6 and 7:
*createmark sets 1 5 6 7
*unsetparametermark sets 1 LSD_DA1 0 0
   # Handle error
Version History
14.0
