*loadcreateonentity
Creates a load (forces, temperature, moment, velocity, acceleration, or constraints) on nodes, fixed points (surface vertices or weld points), surface edges, and surfaces.
*loadcreateonentity geomtype markmask config type component[1-6]
HyperMesh Tcl Modify Command
geomtype
Type of entity the load is applied on (e.g. SURFS).
markmask
The ID of a mark containing the entities that will bear the load.
config
The configuration of the load:
  • 1 - Force
  • 2 - Moment
  • 3 - Constraint
  • 5 - Temperature
  • 6 - Flux
  • 8 - Velocity
  • 9 - Acceleration
type
The type assigned to the load (as defined on the "load types" panel).
component[1-6])
Components of the load being applied.
When applying a force, the active components are 1, 2, and 3, which represent a force x, y, and z-axis, respectively.
When applying a moment, the active components are also 1, 2, and 3, and represent the moment about the x, y, and z-axis, respectively.
For constraints, all of the components are active unless they are set equal to -999999.0. All the other components of the constraints are active in the respective directions.
To apply a temperature of 0 degrees on a surface
*createmark(surfaces,1) 12
*loadcreateonentity(surfaces,1,5,1,0,0,0,0,0,0)
None.
