*setsubmodeltype
Sets the sub-model type supported by ID manaager.
*setsubmodeltype type
HyperMesh Tcl Modify Command
type
The sub-model type. Valid values are HM_INCLUDEFILES and MODULES.
To set the sub-model type to MODULES:
*setsubmodeltype MODULES
   # Handle error
Version History
2017.1
