*renameviewmask
Renames a view saved using *saveviewmask.
*renameviewmask old_name new_name
HyperMesh Tcl Modify Command
old_name
The name of the view to rename. The numbers 1-5 are reserved and cannot be used.
new_name
The new name of the view. The numbers 1-5 are reserved and cannot be used.
To rename a view from "my_view" to "isometric":
*renameviewmask "my_view" "isometric"
   # Handle error
Version History
11.0
