*element1dswitch
Switches the order of 1D element nodes.
*element1dswitch mark_id
HyperMesh Tcl Modify Command
mark_id
The mark ID containing the 1D elements to switch.
To switch the node order of 1D elements 5-10
*createmark elems 1 5-10
*element1dswitch 1
   # Handle error
