*solid_facesfind
Find new 2D faces from 3D elements in select components.
*solid_facesfind mark_id
HyperMesh Tcl Modify Command
This command extracts 2D faces from 3D elements in select components. Then, after filtering out all pre-existing faces, the resulting faces are added to the ^faces component.
mark_id
The mark of components containing 3D elements to consider. Valid values are 1 and 2.
To find faces from components 1-3:
*createmark comps 1 1-3
*solid_facesfind 1
   # Handle error
