*swapcontactmasterslave
Swaps the master and slave entities of groups.
*swapcontactmasterslave mark_id
HyperMesh Tcl Modify Command
Note:
  • In OptiStruct, if slave is a set of nodes, on swapping it is converted to set of elements.
  • In Samcef, it is used to swap master-slave entities of groups MCT and STI. New master and slave entities are created on swapping based on the entity types supported specific to element type and contact type.
mark_id
The ID of the mark containing the groups to update. Valid values are 1 and 2.
Swap master and slave entities of groups with IDs 1 and 2:
*createmark groups 1 1 2
*swapcontactmasterslave 1
   # Handle error
Version History
14.0.130
