*movesubmodel
shortDescription
*movesubmodel source_submodel_type source_filename
HyperMesh Tcl Modify Command
longDescription
Use solversubmodel for a solver submodel or includefile for an include file.
source_filename
The name of the source file to move into the tree.
target_submodel_type
target_filename
The name of the new target file.
Examples
To move the solver submodel with name Part1 to include file with name EngineInclude:
*movesubmodel "solversubmodels" "Part1" "includefiles" "EngineInclude"
   # Handle error
Version History
2019
