*removeassembly
Deletes assemblies and their contents, including recursive children.
*removeassembly mark_id
HyperMesh Tcl Modify Command
mark_id
The ID of the mark containing the assemblies to delete. Valid values are 1 and 2.
To delete assemblies 1 and 2, including all recursive children and their contents:
*createmark assems 1 1 2
*removeassembly 1
   # Handle error
Version History
14.0
