*shell_mesh_smoother
Performs smoothing on selected mesh patches.
*shell_mesh_smoother entity_type mark_id mesh_shape_weight node_displacement_weight iterations
HyperMesh Tcl Modify Command
Performs smoothing on the mesh selection with control on local node displacements and original mesh shape. This smoothing method is particularly useful for CFD while smoothing rough element patches for a wrap mesh.
entity_type
The type of entity to smooth. Valid values are comps and elems.
mark_id
The ID of the mark containing the entities to smooth. Valid values are 1 and 2.
mesh_shape_weight
This is a value between 0 and 1 that defines how much the original mesh shape has to be preserved.
This is a value between 0 and 1 that defines how much the neighboring elements of the node have an effect on the node displacement itself.
iterations
The number of smoothing iterations.
Examples
Smooth all elements with 2 iterations, keeping the original mesh shape strictly maintained and node displacements respecting the neighboring shape:
*createmark elems 1 "all"
*shell_mesh_smoother elems 1 0.4 0.4 2
   # Handle error
Version History
14.0.130
