*markmovetomodule
Organizes entities into a module.
*markmovetomodule entity_type mark_id module_name
HyperMesh Tcl Modify Command
This command organizes entities into a module.
entity_type
The type of entity to organize.
mark_id
The ID of the mark containing the entities to organize. Valid values are 1 and 2.
module_name
The name of the module to organize the entities into.
To move comps 1-4 into module "Test":
*createmark comps 1 1-4
*markmovetomodule comps 1 "Test"
   # Handle error
