*resolvemasslocation
Resolves unresolved mass locations, using a specified search technique order.
*resolvemasslocation mark_id search_technique_order
HyperMesh Tcl Modify Command
This command resolves unresolved (unconnected to any node) mass locations, using a specified search technique order. There are 5 search techniques:
  1. Free end of CBUSH with tag and connected to RBE2
  2. Free end of CBUSH with no tag and connected to RBE2
  3. Shell hole
  4. Shell mesh
  5. Independent rigid node
mark_id
The ID of the mark containing the masses to resolve. Valid values are 1 and 2.
  3. Shell hole
  4. Shell mesh
These techniques are specified individually, or in combination. If multiple search techniques are used, and the location is resolved with one of the techniques, it will not look for remaining techniques. The order is specified using the indices from above. For example 1, 2, 3, 12, 21, 123, 312, etc... The search will be performed in the same sequence as the indices are ordered.
To resolve the mass location using technique 1 only, for mass entities with IDs 10 and 20:
*createmark masses 1 10 20
*resolvemasslocation 1 1
To resolve the mass location using technique 3 only, for mass entities with IDs 10 and 20:
*resolvemasslocation 1 3
To resolve the mass location using techniques 4, 3 and 1, for mass entities with IDs 10 and 20:
*resolvemasslocation 1 431
   # Handle error
Version History
2017.2
