*tableexport
Exports data from a table to a file.
*tableexport name filename delimiter
HyperMesh Tcl Modify Command
name
The name of the table to export.
filename
The full path and filename of the file to write.
delimiter
The character or string to use as the delimiter. The value must be enclosed in quotes. If not specified, the default is a comma (CSV).
Examples
To write out table1 with commas as the separator.
*tableexport table1 C:/table1.txt ","
or
To write out table1 with ABC as the separator.
*tableexport table1 C:/table1.txt "ABC"
   # Handle error
Version History
11.0
