*modent_removecontentsbymark
Removes entities from a modular entity via a mark.
*modent_removecontentsbymark modular_entity_type modular_entity_id content_entity_type content_mark_id
HyperMesh Tcl Modify Command
modular_entity_type
The type of modular entity to update. Valid values are subsystemconfigurations, subsystems and subsystemsets.
modular_entity_id
The ID of the modular entity to update.
content_entity_type
The type of entity to remove.
content_mark_id
The ID of the mark containing the entities to remove. Valid values are 1 and 2.
Examples
Remove the subsystems with IDs 4, 6 and 8 from the contents of subsystem set 2:
*createmark subsystems 1 "by id only" 4 6 8
*modent_removecontentsbymark subsystemsets 2 subsystems 1
   # Handle error
Version History
2020
