*findedges
Finds element free or T-connected edges.
*findedges entity_type mark_id edge_type
HyperMesh Tcl Modify Command
This command finds and displays element free or T-connected edges as plot elements a new component named ^edges.
entity_type
The entity types to find edges for. Valid values are comps and elems.
mark_id
The mark ID containing the entities. Valid values are 1 and 2.
edge_type
The type of edges to find:
  • 0 - Free edges.
  • 1 - T-connected edge
To check the free edges on all of the elements contained in the component fender:
*createmark comps 1 fender
*findedges comps 1 0
To check the T-connectes edges on all of the elements:
*createmark elems 1 all
*findedges elems 1 1
   # Handle error
