*CE_FE_LoadFeConfig
Load or unload an FE config file.
*CE_FE_LoadFeConfig filename load_option overwrite
HyperMesh Tcl Modify Command
This command loads or unloads an FE config file.
filename
The full path and filename of the FE config file.
load_option
0 - to unload
1 - to load
overwrite
Valid only when load_option is 1.
  • 0 - Skip FE types with names or IDs conflicting with existing ones.
  • 1 - Overwrite existing FE types with names or IDs conflicting with current ones.
Examples
To load the FE config file C:/test/my_feconfig.cfg to overwrite existing FE types with those in the file:
*CE_FE_LoadFeConfig 1 "C:/test/my_feconfig.cfg" 1 1
   # Handle error
Version History
13.0
