*solidmesh12lines
Creates a solid mesh in a volume formed by twelve lines.
*solidmesh12lines lines density1 density2 density3
HyperMesh Tcl Modify Command
lines
The line list ID which contains lines that define a solid.
density1
The density of the elements in the first direction.
density2
The density of the elements in the second direction.
density3
The density of the elements in the third direction.
None.
