*pointmodify
Specifies new coordinates for the point.
*pointmodify point_id x/y/z
HyperMesh Tcl Modify Command
point_id
ID of the point to be modified.
x/y/z
New point coordinates.
*createpoint(0,0,0,0)
*createpoint(10,0,0,0)
*window(0,0,0,0,0)
*pointmodify(2,5,0,0)
*createpointsbetweenpoints(1,2,1)
This command is called from the distance panel.
None.
