*systemcommand
Executes a system command.
*systemcommand command
HyperMesh Tcl Modify Command
This is also possible via standard Tcl funcitonality.
command
The system command to execute.
To execute the command ABC and redirect it to the file DEF:
*systemcommand "ABC>DEF"
None.
