*morphreparam
Reparameterizes domains on the mark.
*morphreparam domaintype markdomain
HyperMesh Tcl Modify Command
domaintype
Domains
markdomain
Domain mark number.
*morphreparam (DOMAINS,1)
Domains on the mark are reparameterized, which means that the influence coefficients for the nodes within that domain are recalculated for the handles on the domain.
This command will trigger the update of any existing shapes which are affected by the recalculation.
None.
