*solid_fixedptssuppressor
Suppresses the selected fixed points. Usually paired with *solid_fixedptsmaker().
*solid_fixedptssuppressor point_mark_id
HyperMesh Tcl Modify Command
point_mark_id
1 or 2. Fixed points on this mark will be suppressed.
*solid_fixedptssuppressor(1)
None.
