*split_elements_by_structure_pattern
Creates a transition mesh between refined and boundary regions.
*split_elements_by_structure_pattern refine_mark_id transition_mark_id refine_size
HyperMesh Tcl Modify Command
refine_mark_id
The ID of the mark containing the elements in the refinement zone. Valid values are 1 and 2.
transition_mark_id
The ID of the mark containing the elements in the transition zone. Valid values are 1 and 2.
refine_size
The element size for the refinement zone.
Examples
To refine element 509 to a size of 0.5, using elements 511-518 as the transition zone:
*createmark elements 1 509
*createmark elements 2 511-518
*split_elements_by_structure_pattern 1 2 0.5
   # Handle error
Version History
2019
