*numbersmark
Places the entities in the mark on the numbers mark. This will display the ID of the entity.
*numbersmark entity type mar on
HyperMesh Tcl Modify Command
entity type
The type of entity contained on the mark.
mark
The ID of the mark.
on
Determines whether the entities will be placed on the numbers mark or removed from the numbers mark (1 to put on, 0 to remove).
To place nodes 5, 6, and 7 on the numbers mark:
*createmark(nodes,1) 5 6 7
*numbersmark(nodes,1,1)
None.
