*createcrbrelation
Creates a master-slave relationship for LS-DYNA *CONSTRAINED_RIGID_BODIES keyword.
*createcrbrelation master_component_id slave_component_id
HyperMesh Tcl Modify Command
master_component_id
The ID of the master rigid component.
slave_component_id
The ID of the slave rigid component.
Examples
To create a master-slave relationship between master rigid component 100 and slave rigid component 200:
*createcrbrelation 100 200
   # Handle error
Version History
14.0.120
