*attributeupdatedoublearray2d
Updates an attribute of type 2D double array.
*attributeupdatedoublearray2d entity type id identifier solver status behavior data rows cols
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
id
The ID of the entity.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
data
2D array of doubles.
rows
The number of rows in the array.
cols
The number of columns in the array.
Update an attribute of type 2D double array to [1,2,3] on the material with ID 7.
[4,5,6]
*createdoublearray2d(2,3) 1 2 3 5 6 7
*attributeupdatedoublearray2d(materials,7,615,2,2,0,1,1)
