*adjustgroupsnormal
Adjusts a group normal using an orientation element.
*adjustgroupsnormal name master_slave_flag mark_id elem_flag orientation_element reverse_normal
HyperMesh Tcl Modify Command
name
The name of the group entity to adjust.
master_slave_flag
0 - Use slave
1 - Use master
mark_id1
The ID of the mark of elements to adjust, when flag is 1. Valid values are 1 and 2.
elem_flag
Flag for reversing the contact normal of all or individual elements of the group.
0 - All elements, mark_id is ignored
1 - Individual elements, mark_id is used.
orientation_element
The ID of the shell element that should be used for shell group normal correction on shell face. This element should be part of the selection.
reverse_normal
0 - Correct group normal along the direction of orientation_element normal (default)
1 - Correct group normal opposite to the direction of orientation_element normal
Examples
To reverse the normal of all master elements of the group "test":
*adjustgroupsnormal "test" 1 1 0 0 0
To reverse the normal of all slave elements of the group "test":
*adjustgroupsnormal "test" 0 1 0 0 0
To adjust the normal of group "test" for the elements on mark 1 in the normal direction of reference element id 23:
*createmark elems 1 12 29 53 23
*adjustgroupsnormal "test" 1 1 1 23 0
To adjust the normal of group "test" for the elements on mark 1 in the reverse normal direction of reference element id 23:
*adjustgroupsnormal "test" 1 1 1 23 1
   # Handle error
Version History
14.0.130
