*configedit
Changes the configuration of a selection of elements.
*configedit mark_id config
HyperMesh Tcl Modify Command
mark_id
The ID of the mark. Valid values are 1 and 2.
config
The new configuration name to assign. The new configuration cannot add new nodes.
Examples
To set all plot elements to bar2:
*createmark elements 1 "by config" plot
*configedit 1 bar2
   # Handle error
