*midsurface_unsuppress_conflict_edges
Unsuppresses edges that separate surfaces with differing plate information.
*midsurface_unsuppress_conflict_edges reserved1 reserved2
HyperMesh Tcl Modify Command
Unsuppresses edges that separate surfaces with differing plate information. This happens when one of the surfaces has plate information and the other does not, when the two surfaces have different plate numbers, or when the two surfaces have different plate types.
reserved1
Reserved for future use. Must be set to 0.
reserved2
To unsuppress all edges of the model that separate surfaces with differing plate information:
*midsurface_unsuppress_conflict_edges 0 0
   # Handle error
Version History
2017.1
