*hideview
Hides the entities with respect to a view saved using *saveviewmask.
*hideview name entity_type_id
HyperMesh Tcl Modify Command
name
The name of the view to hide.
entity_type_id
The entity type ID to hide.
Examples
Hide the components (entity type ID 3) in view View2:
*hideview View2 3
   # Handle error
Version History
2020
