*restoreviewmask
Restores a view saved using *saveviewmask.
*restoreviewmask view_name visible
HyperMesh Tcl Modify Command
Restores a view saved using *saveviewmask. The orientation and visible entities can be restored.
view_name
The name of the view to restore.
visible
A flag indicating whether to restore the visible entities or not. Valid values are:
0 - Restore the visible entities and view orientation.
1 - Restore the view orientation only.
2 - Restore the visible entities only.
To restore the view with the name "my_view", including the orientation and visible entities:
*restoreviewmask "my_view" 0
   # Handle error
