*findandremovethreads
Finds cylindrical threads in 3D geometry and replaces them with smooth surfaces.
*findandremovethreads entity_type mark_id max_depth replacement_type flags reserved1 reserved2
HyperMesh Tcl Modify Command
This command tries to recognize threads with a depth less than the specified maximum value. Then the recognized threads are replaced with simple smooth surfaces (usually a combination of cylinders, cones and smooth NURBS surfaces). A search for recognition and removal of threads is performed within a given selection of surfaces or solids. Optionally, the input selection can be considered as a seed selection, allowing attached surfaces to also become involved in the recognition and removal.
entity_type
The entity types to find threads in. Valid values are surfs and solids.
mark_id
The mark ID containing the entities. Valid values are 1 and 2.
max_depth
The maximum depth of threads to find and remove.
replacement_type
The type of major cylinder surface to use for replacing the thread:
  • -2 - Autodecide (by minor diameter for holes, by major diameter for bolts).
  • -1 - Replacement by minor diameter.
  • 0 - Replacement by mean diameter.
  • 1 - Replacement by major diameter.
flags
Flags controlling the mode of thread removal. Bit values are used and the value is calculated as (Bit0).
Bit0
0 - Attached surfaces can also be considered, with input surfaces used as seeds.
1 - Only surfaces specified as input can be considered
reserved1
Reserved for future use. Must be set to 0.
reserved2
To recognize and remove cylindrical threads with a depth less than 5.0 for a given surface selection considered as a seed selection, with auto replacement:
*createmark surfaces 1 1583 1234
*findandremovethreads surfaces 1 5.0 -2 0 0.0 0.0
   # Handle error
Version History
11.0
