*adjustmass
Adjust mass for a selection of components for LS-DYNA.
*adjustmass entity_type mark_id target_mass target_cogx target_cogy target_cogz
HyperMesh Tcl Modify Command
entity_type
Must be set to comps.
target_mass
The target mass.
target_cogx
The target COG x location.
target_cogy
The target COG y location.
target_cogz
The target COG z location.
Examples
To adjust mass for component 100 to 200 with COG at (1000,1000,1000):
*createmark comps 1 200
*adjustmass comps 1 200 1000 1000 1000
   # Handle error
Version History
2019
