*stackdisplay
Displays the stack direction of selected entities.
*stackdisplay entity_type mark_id size
HyperMesh Tcl Modify Command
Displays the stack direction of selected entities. Currently only supported for Abaqus continuum shell elements.
entity_type
The type of entity to display. Valid values are elements and components.
mark_id
The ID of the mark containing the entities to display. Valid values are 1 and 2.
size
The size in model units of the stack display.
To display the stack direction of elements 1-10 using a size of 10.0:
*createmark elems 1 1-10
*stackdisplay elems 1 10.0
   # Handle error
Version History
11.0.120
