*meshline_create_from_plot_elements
Creates meshlines from selected plot elements.
*meshline_create_from_plot_elements mark_id reserved1 reserved2 reserved3 reserved4 reserved5 reserved6
HyperMesh Tcl Modify Command
This command creates meshlines from selected plot elements.
mark_id
The ID of the mark containing the plot elements. Valid values are 1 and 2.
reserved1
Reserved for future use. Must be set to 0.
reserved2
reserved3
reserved4
reserved5
reserved6
To create meshlines from all displayed plot elements:
*createmark elems 1 displayed
*meshline_create_from_plot_elements 1 0 0 0 0 0 0
   # Handle error
Version History
11.0
