*elemswarpagefix
Attempts to fix quad elements violating warpage criteria threshold.
*elemswarpagefix mark_id criteria_file_path max_move break_mode feature_angle
HyperMesh Tcl Modify Command
Attempts to fix quad elements violating warpage criteria threshold. If necessary, tries to move nodes normal to surfaces.
mark_id
The mark ID containing the quad elements to consider. Valid values are 1 and 2.
criteria_file_path
The path to the criteria file. Use "dummy" for using the current criteria, set separately.
max_move
The limit for node movement normal to the surface.
break_mode
Specifies how node associativity of moved nodes is handled. Valid values are:
  • 0 - Associativity is broken for moved nodes.
  • 1 - Associativity is broken for all nodes of an element that has a moved node.
  • 2 - Asscociativity is not broken.
feature_angle
The element feature angle in degrees.
To fix the displayed elements, using the criteria file C:/my_criteria/criteria.txt, with a maximum move of 0.1, without breaking surface associativity:
*createmark elems 1 displayed
*elemswarpagefix 1 "C:/my_criteria/criteria.txt" 0.1 2 30.0
   # Handle error
