*attributeupdatestringarrayelementmark
Updates one element of an attribute of type string array.
*attributeupdatestringarrayelementmark entity type mark identifier solver status behavior index value
HyperMesh Tcl Modify Command
entity type
The type of entity that owns the attribute.
mark
The number of the mark.
identifier
The identifier of the attribute.
solver
The solver number of the attribute.
status
The status of the attribute.
behavior
The behavior of the attribute.
index
Index into the array (first index is zero).
value
The value of the array element.
Examples
Update the first element (index 0) of some string array attributes to steel. The attributes are found on materials with IDs 7 and 8.
*createmark(materials,1) 7 8
*attributeupdatestringarrayelementmark(materials,1,615,2,2,0,0,"steel")
