*surfacesplitwithplane
Splits a surface with an infinite plane.
*surfacesplitwithplane surface plane
HyperMesh Tcl Modify Command
surface
The surface to be split.
plane
The plane used to split the surface
To split surface 1 with the xy plane (normal equals the z-axis):
*createplane(2,0.0,0.0,1.0,0.0,0.0,0.0)
*surfacesplitwithplane(1,2)
None.
