*applyresults
Modifies node coordinates by applying displacements from a .res file.
*applyresults entity_type mark_id scale component
HyperMesh Tcl Modify Command
Provides a yes/no/yes to all answer to the previous command. This is only useful for command files.
entity_type
The entity type to apply the results to. Valid values are nodes, elems and comps.
mark_id
The ID of the mark containing the entities to apply the results to. Valid values are 1 and 2.
scale
The scale factor to use for the displacements.
component
The string that identifies the component to use for the displacements. Valid values are:
total disp
x comp
y comp
z comp
Examples
To apply displacement results from Subcase 1 in the .res file model.res using component total disp to all displayed nodes:
*analysisfileset "model.res"
*inputsimulation "Subcase 1" "displacements"
*createmark nodes 1 displayed
*applyresults nodes 1 1.0 "total disp"
   # Handle error
