*morphmaptosurfacevecoffset
Maps nodes to surfaces along a vector.
*morphmaptosurfacevecoffset entity_type_nodes mark_id_nodes entity_type_handles mark_id_handles entity_type_surfaces mark_id_surfaces use_symmetry use_constraints project vector_id mode offset
HyperMesh Tcl Modify Command
Maps nodes to, or offset from, the specified plane using the temporary shape created by *morphmaptshp and *morphmaptshpedge as a guide. Selected handles can optionally follow behind the morphing operation.
Nodes can be projected on to the plane along a vector, normal to the plane, or projected normal to the elements touching the nodes.
entity_type_nodes
Must be set to nodes.
mark_id_nodes
The ID of the mark containing the nodes. Valid values are 1 and 2.
entity_type_handles
Must be set to handles.
mark_id_handles
The ID of the mark containing any following handles. Valid values are 1 and 2.
Must be set to surfaces.
mark_id_surfaces
The ID of the mark containing the surfaces to map to. Valid values are 1 and 2.
use_symmetry
0 - Do not use symmetry (only option)
use_constraints
0 - Do not use constraints
1 - Use constraints
project
0 or 10 - Project along vector defined by vector_id
1 or 11 - Project normal to the surfaces
2 or 12 - Project normal to shell elements touching nodes
If offset is non-zero, the offset will be measured from the closest point on the surfaces for values of 0 and 1. The offset will be measured along the projection vector or normal for values of 10, 11 and 12.
vector_id
The ID of vector created using *createvector for the projection direction. Must be set to 1.
mode
0 - If *morphmaprecalc has been used to calculate new influences
1 - To recalculate new influences inside this command
offset
The distance to offset nodes from the target.
The offset will be measured from the closest point on the surfaces for values of project of 0, 1, and 2. The offset will be measured along the projection vector normal for values of project of 10, 11, and 12.
To map nodes on mark 1 to surfaces on mark 1 with an offset of 1.2 when not using *morphmaprecalc:
*morphmaptosurfacevecoffset nodes 1 handles 1 surfs 1 0 1 2 1 1 1.2
   # Handle error
Version History
14.0.110
