*renumberelemsnodesasmapgrid
Orders nodes and elements in grid format and renumber nodes and elements with specified start ID.
*renumberelemsnodesasmapgrid elem_mark_id origin_node_id x_ref_node_id elem_start_id node_start_id
HyperMesh Tcl Modify Command
elem_mark_id
The ID of the mark containing the elements to renumber. Only quad elements are allowed. Valid values are 1 and 2.
origin_node_id
The ID of the node to use as the origin of the grid.
x_ref_node_id
The ID of the node to use as the x-axis of the grid.
elem_start_id
The starting ID to use for renumbering the elements.
node_start_id
The starting ID to use for renumbering the nodes.
To renumber all elements, using node 4 as the origin, node 1 as the x-axis, with IDs starting at 100 for both nodes and elements:
*createmark elems 1 all
*renumberelemsnodesasmapgrid 1 4 1 100 100
   # Handle error
Version History
14.0.120
