*hf_setformingdirection
Sets the draw direction for 1-step solver.
*hf_setformingdirection x_coord y_coord z_coord
HyperMesh Tcl Modify Command
This command sets the draw direction for 1-step solver.
x_coord
x-coordinate of the vector direction.
y_coord
y-coordinate of the vector direction.
z_coord
z-coordinate of the vector direction.
To set the drawing direction to the vector defined by (0, 0, 0) and (7214.46,-2031.49418 1206.14793):
*hf_setformingdirection 7214.46,-2031.49418 1206.14793
   # Handle error
Version History
10.0
