*ME_ModuleOccurrenceDelete
Deletes a module part or part assembly, including any recursive contents.
*ME_ModuleOccurrenceDelete id reserved
HyperMesh Tcl Modify Command
id
The ID of the module to delete. The module must be an occurrence.
reserved
Reserved for future use. Must be set as "".
Delete module ID 168 and all its recursive contents:
*ME_ModuleOccurrenceConvert 168 ""
   # Handle error
Version History
14.0
