*morphsymmetrycreateaxis
Creates symmetry dependent on system.
*morphsymmetrycreateaxis name sysptr domaintype markdomain enforce multilat type ucyc orient mv
HyperMesh Tcl Modify Command
name
Name of symmetry.
sysptr
ID of system.
domaintype
Domains
markdomain
Domain mark number.
enforce
0 = approximate
1 = enforced
multilat
0 = unilateral
1 = multilateral
type
Type of symmetry.
ucyc
Number of cycles for cyclical symmetry.
orient
0 = default
1 = x-axis
2 = y-axis
3 = z-axis
mv
0 = do not apply to morph volumes
1 = apply to morph volumes
*morphsymmetrycreateaxis ("mirror",2,DOMAINS,1,1,1,10,3,1,0)
Creates a symmetry dependent on the specified system for the domains on the mark. The symmetry has the values given in ‘enforce’, ‘multilat’, type, ucyc, orient, and mv.
None.
