*surfaceaddpoint
Add a fixed point on a surface at the specified coordinates.
*surfaceaddpoint surfptr x y z
HyperMesh Tcl Modify Command
surfptr
The ID of the surface.
x,y,z
The coordinates of the point.
The coordinates must be within tolerance of the surface. If the coordinates are within the geometry tolerance of an edge, a surface vertex is created. Otherwise, an interior fixed point is added to the surface.
None.
