*newidoption
Defines how new IDs are assigned for a submodel.
*newidoption id option
HyperMesh Tcl Modify Command
This command now new IDs are assigned for a submodel.
id
The ID of the submodel.
option
0 - Minimum available
1 - Maximum available (default)
To set the new ID option as using minimum available for include 1:
*newidoption 1 0
   # Handle error
Version History
12.0.110
