*mechapplyediposition
Applies a position to a mechanism.
*mechapplyediposition mode run_solver
HyperMesh Tcl Modify Command
Applies a position to a mechanism. This will be always used in conjunction with *mechcontructfromedi.
The mechanism must have the enabled flag set to true for this to be possible.
mode
The mode for the position:
0 - Initial position
1 - Active position
run_solver
0 - Directly apply the position to bodies without considering constraints and joints.
1 - Run the solver to apply the position along with constraints and joints.
Examples
To apply position with ID 3 on mechanism with ID 1:
*mechconstructfromedi 2 3
*mechapplyediposition 1 0
To apply the initial position on a mechanism:
   # Handle error
Version History
14.0.120
