*hm_auto_elem_cleanup_new
Attempts to automatically improve the quality of failed elements using node movements and/or local remeshing, along with optional tria reduction.
*hm_auto_elem_cleanup_new elem_mark_id node_mark_id feature_angle criteria_file string_array number_of_strings
HyperMesh Tcl Modify Command
elem_mark_id
The ID of the mark containing the elements to correct. Valid values are 1 and 2.
node_mark_id
The ID of the mark containing any anchor nodes to preserve during cleanup. Valid values are 1 and 2.
feature_angle
The angle used to define features. Valid values are 0-360, and 30 is a common value.
criteria_file
The path to the criteria file. If the criteria are set using *setqualitycriteria, "dummy" can be used as the criteria file name.
string_array
The string array ID that contains the list of entity types. A value of ALL means all entity types. The string array is created using the *createstringarray command. This should always be set to 1. Valid strings include:
  • ConsiderFailedElems failed adjacent layers
    This defines the elements affected by the cleanup. This string contains three values in fixed sequence as:
    • failed
      0 - Consider all elements
      1 - Consider only failed elements
    • adjacent
      Used when failed is 1.
      0 - Do not consider adjacent elements to failed elements
      1 - Consider adjacent elements to failed elements
    • layers
      Used when adjacent is 1.
      The number of adjacent layers to consider.
  • FixFailedElements mode
    Indicates whether to use the QI-based re-meshing to cleanup elements.
    • mode
      0 - Do not perform re-meshing
      1 - Perform re-meshing
  • FixWarpageByNodeMove mode tolerance
    This defines the tria reduction options:
    • mode
      0 - Do not fix warped elements by normal node movement
      1 - Fix warped elements by normal node movement
    • tolerance
      Used when mode is 1.
      The maximum value a node is allowed to move normally to fix the warpage.
  • KeepNonShellConnected mode
    Indicates whether to maintain connectivity between 2D element edges shared with 1D and 3D elements during cleanup.
    • mode
      0 - Do not maintain connectivity. Elements may become disconnected after cleanup.
      1 - Maintain connectivity
  • PreserveFeatures mark_id
    Any 1D plot elements to keep as features during cleanup.
    • mark_id
      The ID of the mark containing the 1D plot elements. Valid values are 1 and 2.
  • QISmooth mode target move_shared move_shared_tol move_free move_free_tol
    Options defining how to smooth nodes to correct the quality.
    • mode
      0 - Do not optimize quality
      1 - Optimize quality
    • target
      The QI target value to attempt to achieve.
    • move_shared
      0 - Move nodes along shared edges only
      1 - Move nodes along and across shared edges
    • move_shared_tol
      The maximum amount a node is allowed to move across a shared edge when move_shared is 1.
    • move_free
      0 - Move nodes along free edges only
      1 - Move nodes along and across free edges
    • move_free_tol
      The maximum amount a node is allowed to move across a free edge when move_free is 1.
  • ReduceTriaElements reduce_trias keep_edges
    • reduce_trias
      0 - Do not perform tria reduction
      1 - Perform tria reduction
    • keep_edges
      Used when reduce_trias is 1.
      0 - Do not preserve edges
      1 - Preserve edges
  • RemoveInverseElements mode angle
    Indicates whether to split warped/split quads.
    • mode
      0 - Do not remove
      1 - Remove
    • angle
      The inversion angle to consider.
  • SplitWarpedSkewedQuads mode
    • mode
      0 - Do not split
      1 - Split
number_of_strings
Integer indicating the size (number of strings) in the string array created using *createstringarray.
Auto correct all elements, using anchor node 50, defining the criteria via a file, no preserved features, considering 7 adjacent layers, using remeshing and tria reduction:
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elements 1 all
*createmark nodes 2 50
*createstringarray 9 "PreserveFeatures: 0" "ConsiderFailedElems: 1 1 7" "RemoveInverseElements: 1 150" "ReduceTriaElements: 1 1" "FixFailedElements: 1" "QISmooth: 1 0.2 0 0 0 0" "KeepNonShellConnected: 0" "SplitWarpedSkewedQuads: 1" "FixWarpageByNodeMove: 0 0"
*hm_auto_elem_cleanup_new 1 2 15 "dummy" 1 9
   # Handle error
Version History
2017.1
