*morphremoveconstraint
Remove constraint(s).
*morphremoveconstraint nodetype marknode option
HyperMesh Tcl Modify Command
nodetype
Nodes or morphconstraints
marknode
Node or morphconstraint mark number.
option
0 - Remove nodes on mark from morph constraints.
1 - Remove morph constraints on mark.
2 - Remove all morph constraints.
*morphremoveconstraint (NODES,1,1)
If option is 0, any constraints on the nodes on the mark are removed.
If option is 1, all constraints are removed.
Note: The options have changed from HyperMesh versions prior to 8.0.
None.
