*CE_FE_CreateUCCFromConnector
Creates a connector control from a connector.
*CE_FE_CreateUCCFromConnector cc_name ce_id
HyperMesh Tcl Modify Command
cc_name
The name of the connector control to create.
ce_id
The ID of the connector to use.
Examples
Create a connector control named "my_acm" from connector 101:
*CE_FE_CreateUCCFromConnector "my_acm" 101
   # Handle error
Version History
2021
